Cloud-based tools have come as a boon for all business owners. For SMEs, a cloud-based Project Management software is more than just a “good to have” tool, it is a necessity. The Project Management tool comes packed with numerous benefits that will scale your business and help in increasing profits.
What is cloud based project management?
Cloud-based project management entails project management via online tools stored on remote servers. It enables teams to view project data from any location, collaborate in real time, and monitor progress. Centralized data storage, collaboration tools, task management, scheduling, resource allocation, reporting, integration capabilities, and comprehensive security measures are among the key features. Cloud-based solutions are popular due to their adaptability, accessibility, and low cost, making them perfect for remote teams and dynamic work environments. Users have access to the most recent features and upgrades thanks to regular updates.
These tools are undeniably the need of the hour. Let us look at the reasons.
5 Reasons To Use a Cloud-Based Project Management Tool
Using a cloud-based project management solution provides the following benefits:
Ease-of-use
One of the prime benefits of using a Cloud-based Project Management software is the ease with which all your employees can use this tool. There is no training required. Unlike the standard procedures of task management and tracking progress, these tools are a bundle of multiple features that make working on a project seamless.
Faster Collaboration
Because all the team members and leaders are on the same page (literally), collaborating with everyone becomes as easy as a breeze. With real-time updates to the sheets, you can not only track the progress but also assign and monitor resources utilized for the task. With time trackers set in place, there will be no delays in tasks. In situations when certain clarifications are to be made, leaders or members can leave notes with each task. This reduces any chances of confusion and saves time.
Multitasking
With an efficient Project Management tool, you can perform multiple activities from one place. Project Management tools come with project schedule management, task management, budgeting, planning, and communication features which saves a lot of your time.
These tools act as a centralized platform for multiple tasks. If used in the right way, the Project Management tool can handle all your project-related needs.
Remote Access
Cloud-based CRM Software and Project Management tools allow for real-time remote access to all documents and project-related updates. Being suitable to even run on mobile phones, you can work seamlessly while you are on-the-go.
Some apps also come with offline mode, which will update itself once your device gets access to the internet. This not only saves time but also increases productivity. Now, you will no longer miss out on crucial workdays.
Cost-Effective and Secure
Needless to say, Project Management tools are highly cost-effective. Unlike the traditional methods of using multiple tools for all your tasks, all-in-one CRM and Project Management tools can perform all the tasks for the cost of one. Because the data is stored on Cloud, all your documents will be safely stored, reducing the chances of data loss or theft.
What Does The Apptivo Project Management Tool Offer You?
Apptivo Project Management Tool includes a wide range of tools that help with project planning, execution, and collaboration. Among the primary offerings are:
Project Templates
The tool Project comes integrated with the Project Management tool. This tool offers predefined templates to start a project with the click of a button. These templates are reusable. They can be used as they are or be customized as per the needs of the businesses.
Project Templates save a lot of your time as you can set milestones and use them when you start new projects. Once you change the basic template, all the future projects will have the changed milestones.
Milestones and Task management
The tool also allows for efficient task management using the interactive Gantt Chart. For any project, milestones can be made to measure the progress of each task. Using the Project Management tool, you can allot time schedules for each step of the project. These milestones help breakdown the total workload and give out a clear perspective of all the events that go in towards completion of the goal.
Billing Management
Project Management software from Apptivo is indeed one of the most comprehensive tools out there. This app also comes with a budgeting feature that helps you to send out planned and well-calculated invoices to your clients.
Based on the type of your business, you can use a Flat Rate chart (for sending out a flat rate to all your clients), a Milestone-based chart (for task-based projects), and a Time-Based chart (to charge your clients based on monthly or weekly timelines).
Project Customer Portal
Nearly all of the Apptivo software and tools come with the feature of creating a customer portal. The Customer Portal is a dedicated portal or ID which is given to customers or clients so that they may track the progress of tasks or projects they are involved in.
Project Management Customer Portal lets your clients view the progress of the tasks, and estimated duration of completion. This feature encourages transparency and reduces the chances of delay in the submission of the projects or making deliveries. In addition, you can set web portal actions for those customers from the Projects App.
Customize apps
Customizing an app’s master layout entails modifying its user interface by adding or removing fields based on user requirements. This procedure simplifies the UI, makes it more intuitive, and improves the user experience. Identify requirements, add useful fields, delete extraneous ones, arrange them logically, and take user permissions into account. Iterate and improve based on user feedback to achieve the best results.
Final Thoughts
Choosing the right Cloud-based Project Management App can be tiresome, especially with so many options available. For the development of any business, it is pivotal to select a tool that offers the most number of features, matches your needs, is easy to use, and comes with a small price tag. Yes, we are talking about Apptivo. So, choose the best tool, today.
