Implementations and Enhancements
- Export Custom table attributes
- Custom Ref App in 360 view
- Items Sales By Category report in Invoices app
- Enhanced Estimate conversion
- Bulk Void Invoices
- Row-level preview in the table section
- Unique Line Number Generation
- Barcode Generation
- Export in Target Lists
- Contacts Enrichment
- Force syncing emails
- Advanced Search of Ref App fields in the date range
One of the major releases made is the export option which includes standard and custom table attributes. You are given the choice of exporting the data with the current view, or with all the fields that exclude table and includes the table in the Contacts App.
Custom Ref App in 360 views
You can view the associated data of the standard ref app and custom ref app in a 360-degree tab. Now the 360 Degree Association toggle is supported in Opportunities, Projects, and Invoices App.
Financials
The Invoices can now be listed based on the item sales by category. This is one of the new features implemented in this deployment. This report can bring out all the items based on the category, status and filtered based on any specific time span.
The estimates can be converted any number of times using the custom conversion. Allowing custom conversion for multiple times is an important enhancement in the Estimates App.
Bulk Void Invoices
We have implemented the feature of voiding the invoices in bulk. This saves you time and makes it more productive.
The Row-level Preview option for the line level sections is now implemented in Apptivo. Once the preview option is accessed, you can view and edit the line level attributes in the side panel pop-up.
Supply Chain
Creation of line numbers is enabled with the use of the counter attribute in the line level. You can now automatically generate line level numbers in the Purchase Orders and the Orders App.
Barcode Generation
Generating barcode can be used to scan the generated barcode from the printed Purchase Orders or Orders and it would deliver the purchase order or order number to the device that it is connected to. Generating barcode in one of the most awaited features implemented in Apptivo.
The export option is now added to all the tabs in the Target App. All data in the Targets App can be exported by segregating them.
Contacts Enrichment
Any contacts that you save in the Contacts App can be enriched with additional information using this feature. This enables you to enrich the contacts’ details.
You can force the IMAP syncing using this feature when the email sync fails in Apptivo. This is one of the long-awaited features in Apptivo.
General Updates
We have enhanced the advanced Search option by extending it to search the ref app field data in the date range formats(Date format, Date and Time format).
Catch you shortly with the next set of our updates in Apptivo!
Till then, stay tuned for updates in our blogs and posts!
Grace
